Grading a parking lot and eg surface.
I have a 3d poly line drawing of a parking lot, road structure, pond. I have already created my allignment, corridor , etc for the road. Now I have tk grade the parking lot and the site so I turned them into feature line and assigned elevations as well as labeled them. Now I'm new to autocad and basically did the grading completly from youtube because of complications with my classes. So my questions tk you as what do I now add after this do I need parcels? Also how should my grade/slopes look on the elevation editor tab look. As you can see by my questions I'm fairly new so any insight on how I should go about thisthis drawing would help. Thank you 1524859715109-63337365.jpg
john.vellek has embedded your image(s) for clarity
john.vellek
Hi @Anonymous,
I am traveling at present and will add a suggestion later if you have not already received some replies. Please add your drawing to a post so others can see what you have done so far and please indicate if you are using Civil 3D or plain AutoCAD.
John Vellek
