AutoCAD Forum
Google Map to AutoCAD
7 REPLIES 7
Message 1 of 8
62169 Views, 7 Replies
Hello, I need to create a scaled site plan as shown below in Autocad 2013 using Google Map. Can somebody explain how to proceed ?
Thanks in advance.
Thanks in advance.
7 REPLIES 7
Message 2 of 8
wispoxy
wispoxy
Giving you all I got Cat Very Happy
Here is a similiar thread:
http://forums.autodesk.com/t5/autocad-lt-general-discussion/is-there-any-way-to-import-a-google-eart...
A Comment:
in google you can use a "measure" tool to get distance between 2 points. Use this distance to scale the image in your drawing, so it's true scale inmodelspace. In paperspace, scale viewport in the usual manner, say 1"=1 mile (1 : 5280 if PS is inches & MS is feet)
Using the Measure Distance Tool to Scale off of Google Maps
Google Map
Google has some pretty cool tools that are available for the CAD operator. With the advent of Google Maps and Google Earth, its even possible to scale drawings onto CAD. Today I’m going to show you a quick and dirty way of doing such a task.
Google Earth Setting
First of all, once you find the address of your desired site on Google Maps, go ahead and change the settings to “Google Earth” Mode.
Tracing the Building
From here, most would simply take a screen shot and do their best to trace the site and perhaps the outline of the building. The problem is obvious; there’s no real way to accurately find the real length of the building from just the Google Map.
measure distance
Just recently, Google integrated a measurement tool that allows us to do just that. All you need to do is right click on an area of the map and click “measure distance.”
Scale Building
All you need to do from here is click on two points for the map to scale off a distance. In this case, the south exterior wall of Portland City Hall is approximately 120′.
Cad Scaling
With this knowledge, you can go back into CAD and draw a construction line that’s 120′ long.
image scaled in cad
Now, since you have a relation between the google image and a hard length in CAD, all that’s left is to run the “align” command and scale both the original line and the imported image to real world dimensions. Now you can do a trace with real world lengths and without 90% of the guesswork!
Obviously, this is a very quick and dirty method. And this Map Scaling is relatively useless if you’re going to try to do any construction or as-builting from Google Maps. However landscape designers can use this tool to get a rough estimate of how much material they will need on a site. Civil designers can use this tool to get a rough estimate on pervious vs impervious area to do storm water calculations or even cut/fill calculations. If you only need to draw something with a degree of accuracy of within a few feet, this “measure distance” function will get you a quick idea of what you’re up against with a minimum of time.
A Comment:
Google Map
measure distance
Scale Building
Cad Scaling
image scaled in cad
Message 3 of 8
Message 4 of 8
wispoxy
wispoxy
Your post was blank
Your post was blank
Message 5 of 8
bham4ever
bham4ever
Or you can got to Apps and purchase Plex.Earth 3
http://www.plexearth.com/
It's around 200 bucks a year and you can import either Google or Bing images.
Also topography from either map.
I love this app for Civil preliminary design work.
I think you can try it for free to see if you like it.
Wll worth the money in my book.
"Never say Never"
"Never say Never"
Message 6 of 8
in reply to: wispoxy
Sorry for late reply. But, thanks that was what I needed. Kudos
Message 7 of 8
wispoxy
wispoxy
Glad I was able to answer your question.
Message 8 of 8
sakar_deepak
sakar_deepak
Hi dear @wispoxy
what is the accuracy level of 'measure distance' of Google earth ?
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
Hi dear @wispoxy
Regards
Deepak Gupta
Architect
AutoCAD Inside the Factory
