Message 1 of 9
Given line dimension not same when checked
Good day . Please for your help as I stuck with the line dimensions. When I enter the desired by me length of the line does not match when I check it with Distance command. Also the line length does not correspond to its given dimensions , example : line command for 300 cm looks shorter than line given 60 cm length.
I have checked all my settings in -UNITS and -DWGUNITS to make sure they are all in centimetres.
After many attempts and no success I have restored Autocad settings to default but still no joy.
Please see the attached file for more info.
Your support with this matter will be highly appreciated.
Thank you in advance!
Kind regards
Kristina
