Given line dimension not same when checked
kristiinna
Observer Observer
Message 1 of 9
kristiinna
Observer
Observer
Good day . Please for your help as I stuck with the line dimensions. When I enter the desired by me length of the line does not match when I check it with Distance command. Also the line length does not correspond to its given dimensions , example : line command for 300 cm looks shorter than line given 60 cm length.
I have checked all my settings in -UNITS and -DWGUNITS to make sure they are all in centimetres.
After many attempts and no success I have restored Autocad settings to default but still no joy.
Please see the attached file for more info.
Your support with this matter will  be highly appreciated.
Thank you in advance!
Kind regards
Kristina
Replies (8)
Message 2 of 9
imadHabash
Is there any different if you turn OFF the dynamic input F12 ?
Would you please attach here the CAD dwg file?
Imad Habash
Message 3 of 9
pendean
Community Legend
Community Legend
@kristiinna Show your work: share with us your actual DWG file here please.
Message 4 of 9
kristiinna
Observer
Observer
Good day .Thank you for the prompt reply . No , did not change with F12.
Message 5 of 9
kristiinna
Observer
Observer
Here is attached DWG file.
Message 6 of 9
imadHabash
Nothing weird in the file... Click on below image to see how it works normal.
Imad Habash
Message 7 of 9
pendean
Community Legend
Community Legend
@kristiinna Thanks for the file: it appears you have not chosen any method to draw those likes to achieve the distances you listed.
How do I recreate your white lines exactly like you did? The ones in read match your intent
 See attached.
Message 8 of 9
kristiinna
Observer
Observer
Hi Pendean .
Could you please share with my from where I can choose the method to draw ?
Thank you for your help.
Regards
Kristina
Message 9 of 9
pendean
Community Legend
Community Legend
@kristiinna wrote:
...Could you please share with my from where I can choose the method to draw ?
Watch the video in an earlier reply to you, here is the link
https://forums.autodesk.com/t5/autocad-forum/given-line-dimension-not-same-when-checked/m-p/13425138...
