Getting the sum of attribute values.
mlfgale
mlfgale
We have blocks that we use for defect locations. The block has an attribute for a number that is the linear feet (or sf) of a defect area. Is there a way to get the sum of the attribute for all of the blocks into a table? I've messed around with fields and found a script that can do it, but I'd like to not have to use a script each time (which makes me have to select the defects, and there are many different ones) to update it when we add more defects. Thanks for any help you can provide.
Mark
ВeekeeCZ
Explorer the DATAEXTRACTION command
john.vellek
HI @mlfgale,
@ВeekeeCZ's suggestion of Dataextraction is what I suggest as well. If you have a sample file that contains this data I am happy to explore and demonstrate how you might get this to work.
John Vellek
john.vellek
HI @mlfgale,
I haven't seen an update so I created an attributed block, ran a data extraction and then exported to Excel to add the SUM. In addition, if you select the last row of the table and insert a row below it, unlock it, then you can add a formula that will create the SUM. No need to even export outside of the drawing file!
John Vellek
mlfgale
Thanks for your help!
ВeekeeCZ
HERE is quite a recent thread how to sum a table column within autocad and dynamically.
