Get intermediate steps between two lines.
Hi everybody,
I need to get the intermediate steps between two lines. I attach you an image. I should can choose the number of these intermediate lines.
Any idea?
Thank you so much!
Ed__Jobe
Plain AutoCAD doesn't have anything that can figure that out for you. You would have to write a program to figure out the functions to plot those curves and then add a curve for each function.
Ed
How to post your code.
leeminardi
Working in the top view in the follow drawing I created the red line a Z = 0 and the yellow arc at z = 6.
I then used loft to create a surface between the line and arc.  The section command was used to create the green lines at z = 1, 2, 3, 4, and 5.
The resulting lines were all moved to z = 0 and the surface deleted.
lee.minardi
imadHabash
as much as i understand ... by CENTERLINE (Command) you can create an associative centerline by selecting two line segments. A centerline is created between the apparent midpoint of the start and endpoints of the selected two lines. When selecting nonparallel lines, the centerline is drawn between the imaginary intersection point and the endpoints of the selected lines.
Imad Habash
Thanks! Instead, I prefer do in Rhinoceros and export them to autocad.
Thanks so much!
