Attribute Dialog Box
Is it possible to turn on/off the attribute dialog box by block?  In other words when I build the block can I set a variable that turns the pop window off for one block and on in another?  I want to be able to insert one block and have the dialog box pop up and insert another block that the box does not pop up.
Not that I know of....the dialog box appearing or not depends on the system variable ATTDIA.
Area Object Link | Attribute Modifier | Dwg Setup |Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
cadffm
imadHabash
NO you can not . 🙂
Imad Habash
cadffm
Looks like a translation problem,
Acad can, Imad can't
Sebastian
Moshe-A
@Anonymous  hi,
here is a lisp command (RNI) to do what you want. it's data list is built from the following dotted pair items:
the number in the dotted pair is the value of attdia to be before insert
(setq blockData^ '(("blk101" . 0) ("blk102" . 1) ("blk103" . 0) ("blk104" . 1))
replace each "blnnn" with your blocks
enjoy
moshe
; Robert Noha Insert
(defun c:RNI (/ insert_block ; local function
	        blockData^ blkName savAttdia)
 (defun insert_block ()
  (if (setq item (assoc blkName blockData^))
   (setvar "attdia" (cdr item))
  (command-s "insert" blkName)
 ); insert_block
 ; here start c:RNI
 (setq blockData^ '(("blk101" . 0) ("blk102" . 1) ("blk103" . 0) ("blk104" . 1)))
 (if (/= (setq blkName (getstring "\nEnter block name: ")) "")
  (progn
   (setq savAttdia (getvar "attdia"))
   (cond
    ((tblsearch "block" blkName)
     (insert_block)
    ); case
    ((findfile (strcat blkName ".dwg"))
     (insert_block)
    ); case
    ( t
     (vlr-beep-reaction)
     (prompt (strcat "\nblock " (strcase blkName) " is not found."))
   ); cond
   (setvar "attdia" savAttdia)
  ); progn
 ); if
 (princ)
