Geo Map command error
jamied2000
jamied2000
I keep getting this when trying to do anything with the geolocation ribbon tab or when i type in the command.  I keeps saying unknown command.  This happens to all the geolocation commands.
Albert_Rius
Please can you check if the solution from this link helps?
http://knowledge.autodesk.com/article/GEOGRAPHICLOCATION-Unknown-command-after-installation-of-Geolo...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
jamied2000
I have done others since i have applied the hot fix back at the beginning of November.
Albert_Rius
If you load manually the arx, can be loaded and the commands are recognized?  (Appload -> AcGeoLocationUI.arx)
Are you on AutoCAD 2014/2015?  if yes, did you installed the Poodle vulnerability hotfix?  if not, please do it:
AutoCAD 2014/2015: Autodesk Licensing Hotfix - POODLE SSL v3 vulnerability (CVE-2014-3566)
Cheers
Albert Rius
Technical Support
jamied2000
I got it fixed.  I had to reapply the geolocation hot fix.  Now it works fine.
