Crashing
Crashing
Message 1 of 22
Crashing
Hey, I need some help here....
I installed the 2016 version on my desktop, and ir works fine, unless I nedd to save something, then it takes too long (even if it's a single line), and eventually crashes without saving the changes.
I'm losing my work here, and don't know what to do...
The same thing was happening when I had the 2014 version, so I thought it was something in the software, end unistalled and installed the 2016.
But it kept happening!!
Help please...
Accepted solutions (3)
Replies (21)
Message 2 of 22
Alfred.NESWADBA
And when two different software packages show the same issue I guess it has to do more with
  • Antivirus (or other defending software)
  • Windows user profile
  • permissions (maybe on the network, if you have a server or NAS you try to save to)
  • Operating system
At least, when saving to your local harddisk with disabled antivirus software creates again a crash, then let us know what crash info you get.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 22
hey there...
first of all, thanks for your answer!
The thing is, a don't get any error messages. I have the exactly same software on another machine, and it works just fine.
I've tried to change the destiny folder when saving (it saves on the company server by default), thinking it might have something to do with the permissions of the machine, but no such luck.
It just crashes most of the time...
Some even suggested that it might be related to user's action (it's not on my machine, it's a colleague's), but it crashes qhen he's using, when I'm using, even when other people are using... I don't know what else to do, next step will be calling a technician...
I'm at a loss here  😞
Message 4 of 22
Message 5 of 22
pendean
Community Legend
Community Legend
You're not really providing much information for remote assistance... .
What is your Windows OS? Where are you trying to save files to? Are you logged into Windows as a full administrator? Did you by change invoke any "migration" process form 2014 or from 2016 installed on another PC?
If the problem persisted in 2014, when exactly did that start and what had changed on your PC or network at about the same time?
Have you seen this Autodesk topic, it may help http://forums.autodesk.com/t5/objectarx/autocad-crashes-when-saving-drawing-file/
Message 6 of 22
nrz13
Have you tried disconnecting the computer from the network altogether (pull the ethernet cord or disable the wifi card) and save to the desktop only?
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 7 of 22
Hey guys...
first of all, thank you all so much for the help you've been giving me!!
Turns out the file I was working on was somehow corrupted, making it waaaay to heavy for the program to make a smooth auto save, and it caused it to crash every time.
I start a fresh file, and it stopped....
Still, I have no idea what happened to that file....
it was at the same moment that some machines were moved around the office, and the program was reinstalled.... it could have something to do with it....
anyway, thanks guys!!!
until next time!!
Message 8 of 22
BobHoghton12
I am haveing the same problem.  I have autoCad 2016 lt.  Running on windows 7.  Every time i close a file from a third part AutoCAD crashes i have sent lots of reports i i have recived an Email from AutoCAD see below.  Which sayes to Update Marvell printer driver   which is a link to a web page http://www.marvell.com/support/downloads/search.do which does not have any printer drivers on it how ever i have downloaded any driver which relate to Windows 7 but all relat to changing the relivent device driver and do not say which device drive i need to change I have tryed a few but each one tells me i have the best driver.  After the Wast of time i am on better off AutoCad Lt crashes two or three time a day lossing  my latest work!!!
AutoCAD LT® 2016
PLEASE DO NOT REPLY TO THIS E-MAIL. THIS E-MAIL ADDRESS IS USED BY AUTODESK AUTOMATED SYSTEMS AND IS NOT MONITORED.
Dear AutoCAD LT® 2016 Customer:
Autodesk has analyzed the error report you recently submitted. Errors similar to this have been resolved by the following Technical Solution.
We recommend that you apply this Technical Solution, or contact your system administrator.
 Error Report Summary
Computer
Date
The steps you provided Autodesk
Not provided
25/06/2015
crash crash crash!!!!!!!
 Technical Solution
Note: You must log in as an Administrator to apply Technical Solutions.
 Need Help?
Contact your reseller or support provider with additional questions about this Technical Solution.
Not provided: The CAD Manager Control utility (not available with all products) can be used to provide the computer name with an error report.
Message 9 of 22
pendean
Community Legend
Community Legend
>>>... i close a file from a third part AutoCAD crashes ...<<<
What does that mean please?
Instead of writing CRASH CRASH CRASH on that pop-up, read what they actually want you to write in there above that box: it's a crash report, they already know it crashed 🙂
Message 10 of 22
BobHoghton12
It crashes so oftern  i have given up on spending time writing what happen.  then reciveing an email which does not explane hope to solve the problem
Message 11 of 22
Alfred.NESWADBA
What means "often"? Once an hour, once a day, every two minutes?
I can understand that it is frustrating, but on the other side don't estimate to get it repaired as long as Autodesk does not know how to reproduce it.
For developer it's simetimes "ah, that click" ... to be able to reproduce the issue and then it's just a few minutes to repair it. As long as they don't know where to search (especially when crashes depend on drivers, drawings, apps/plugins, ...) it might be a never ending story (because not to find).
- alfred -
Alfred NESWADBA
Message 12 of 22
BobHoghton12
As i said in my post about three time a day.  it normally happen when i close a file from a third party.
Message 13 of 22
Alfred.NESWADBA
Then if the file's source is always that "third party" check the consistence of the file, maybe something in the file the source of your crashes.
What software (exactly name and service pack) did this "third party" use, what version exactly do you use? Especially when there are verticals like Architecture, MEP, Civil3D, ... it might be important to know.
- alfred -
Alfred NESWADBA
Message 14 of 22
BobHoghton12
I do not know i get the attached message every time i open one of them
Message 15 of 22
M_Hensley
It might help if instead of OPEN you use RECOVER when you get these drawings.
Message 16 of 22
BobHoghton12
It has been sugested by M_Hensley (Advisor)
Message 17 of 22
BobHoghton12
I have opened using the RECOVER and it still crashes
Best Regards
Bob Hoghton
Message 18 of 22
I was ask for a replacement file from who/where you got this one from.
Message 19 of 22
BobHoghton12
It is not only files from this this person i files from other people.  I get the same problem.  It only seem to be since i installed 2016
Message 20 of 22
pendean
Community Legend
Community Legend
Looks like you are receiving DWG files created from other applications than AutoCAD. No fix. But...
- Can you XREF them without crashing?
- Can you INSERT then EXPLODE them into your template files and have not not crash?
- Can you share a file that crashes here for us to test? We all have 2016 too and it's rare that it crashes for us from external client files.
