AutoCAD Forum
Generating table in Autocad
6 REPLIES 6
baliasM74U3
555 Views, 6 Replies
Hi Experts
I was just trying to generate a table using table option in Auto cad. For my use, I want to add a serial number section as the first column. In the image attached, I have typed in the serial number. Is there any smart way to generate serial number like we do in excel. I have tried exporting an excel file to autocad, I didn't find that handy for editing.
Can some experts advice me on this ? Image attached.
6 REPLIES 6
imadHabash
in reply to: baliasM74U3
click on below image .. to see how it's work .
  • Double click inside a cell .
  • Enter a numeric .
  • Select the cell and Click the grip in the lower right corner.
  • Drag the grip through the cells you would like to automatically increment.
Imad Habash
baliasM74U3
in reply to: imadHabash
Thanks Heaps
baliasM74U3
When it come to 2 digits, the numbers are going multi line, I just need that in a single line. How could that be done ? What are the parameters that need to be adjusted to get required result.
imadHabash
it's work fine here !! you may need to change you're text style font , i'm using Arial . click on below image
attache here your CAD dwg sample for testing please ?
Imad Habash
baliasM74U3
PFA
imadHabash
You have improper table settings !! start a new CAD dwg and see how it will work fine .
Imad Habash
AutoCAD Inside the Factory
