AutoCAD Forum
functional problems
3 REPLIES 3
387 Views, 3 Replies
functional problems
Hello, recently I ran into a problem when using the program. The "fill color" function in the autocad has disappeared, for the dimensions. Because of what the problem was posed, it is not clear.
Can anyone help me with this issue?
I did a reset of the autocad, it did not help.
functional problems
Labels (1)
3 REPLIES 3
imadHabash
imadHabash
Hi and Welcome to AutoCAD Forum,
If you start a new empty CAD dwg and make a linear dimension , any changes ?
also try to check if any updates needed from your Autodesk Desktop App .
Imad Habash
Imad Habash
in reply to: imadHabash
When starting a new dwg, everything is the same. The program does not require updates.
pendean
pendean
Community Legend
Community Legend
What does ABOUT command list as your version and variant of AutoCAD?
Do you have 3rd party addons installed?
have you reinstalled AutoCAD yet?
Can you share a DWG file with the problem for us to examine?
AutoCAD Inside the Factory
