& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Are there any way to change a drawing from mechanical to only autocad? I want a drawing only in autocad, completely clearn of properties of mechanical to manipulate and do changes of the drawing in autocad.
Thanks in advance,
Rosa
This can vary depending on your version but you need to export the drawing. If you have mechanical or other vertical, you should be able to export the drawing in a way that will eliminate all things mechanical. If not, then -EXPORTTOAUTOCAD should do the trick for you.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
