Announcements
Autocad 2013 copy and paste doesnt work
When I try to copy and paste in AutoCAD 2013, it doesn't work...
cadffm
Create two blank new file from acad.dwt, try to copy&paste between both.
Is working?
So what happen in your normal files, any messages?
What is the last feedback after pasting, asking Acad for a insertion point? And then?
Upload both files for us.
Sebastian
imadHabash
There are many reasons for such a problem ... please read here this AKN article and see which step help you . >> Click <<
Imad Habash
TheCADnoob
What is the process you are using to copy? are you using keyboard, are you right click etc.?
CADnoob
jayhar
<<<<<When I try to copy and paste in AutoCAD 2013, it doesn't work...>>>>>>
1, First Enter new value for CLASSICKEYS <0>, to active copy paste.
2, Same BLOCK name cannot paste, you should PURGE first where you want to past.
  or Explode the Block.
3, If its Xref file, you should be BIND, and copy past
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
