Is it possible to create dimensions with fractions having denominators other than 2, 4, 8, 16, 32, etc...
If I wanted to have a dimension that read 18 1/6" inch (because that is the actual length), is that possible?
I have tried changing the UNITS and [DIMSTYLE -> Primary Units -> Unit format:] and [DIMSTYLE -> Primary Units -> Precision:] but the dimension always has a denominator that satisfies DENOMINATOR = 2^X. It seems (that is the pattern).
I am not a heavy AutoCAD user and I did search but couldn't find anything. I may be missing something fundamental here.
Any help is appreciated, thanks!
Solved by Kent1Cooper. Go to Solution.
For some discussion of the complications involved in denominators other than powers of 2, see this thread.
[... and @pendean, it's not about a non-standard scale, but about fraction denominators in dimension text.]
