Is there a way to creating countour linework from elevation color mapping?
joemcninch
joemcninch
Hi all,
I have imported a point cloud into AutoCAD and my task is pulling the floor topography out.  I have successfully created a color map by elevation, but my question is, can AutoCAD automatically create the actual contour line work or do I have to manually trace the apparent contours where the colors change to indicate grade?
Joe M.
john.vellek
HI @joemcninch,
I just found this post from a few weeks ago.  Were you able to resolve the issue?  If the point cloud consists of structured data there is SOME intelligence to the way you can create certain geometry from the point cloud. Otherwise, you will need to "trace" by snapping to the point cloud points.
John Vellek
john.vellek
Hi @joemcninch,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
