AutoCAD Forum
Font swis721 blkex bt in autocad is error
10 REPLIES 10
Message 1 of 11
maria.flores7UKN6
501 Views, 10 Replies
When tried s3d .sha converted to dwg with font "Swis721 blkex bt". It will not show correct font.
Cannot even read the text.
Tags (1)
10 REPLIES 10
Message 2 of 11
Patchy
in reply to: maria.flores7UKN6
What should it look like? I got it as this:like this.JPG
Message 3 of 11
maria.flores7UKN6
in reply to: Patchy
Yes, it correctly shows in your end. But in my autocad, its only box..and cannot read it.
Message 4 of 11
Your Text Style is calling for a .shx file of that name [which doesn't exist for me], not the .ttf file it should be calling for.
Kent Cooper, AIA
Message 5 of 11
pendean
This is a TTF (Windows) font, fix it in your file's STYLE command to be the same
Message 6 of 11
maria.flores7UKN6
in reply to: pendean
I have this ..it is already .ttf
Message 7 of 11
Patchy
I don't know why your font grayed out, try to install the new Swis... fonts attached
Message 8 of 11
maria.flores7UKN6
in reply to: Patchy
the output is still the same when I installed the fonts you sent
Message 9 of 11
pendean
Thanks for the screenshot: your AutoCAD session is using a font that is not the one you need.
It is finding the wrong font first before the TTF you actually need.
Message 10 of 11
maria.flores7UKN6
How to set to use the correct font?
Message 11 of 11
pendean
Ask your IT person to help you search for then delete all Windows fonts not installed where they nee to be, restart your PC, then test once more.
AutoCAD Inside the Factory
