Font - Diamond Character
Within the food industry there is a need to put Square Box Section "on the diamond" namely it is rotated 45deg
This can be notated by a square box that is rotated through 45deg
This notation is used within the annotation.
Unfortunately there isn't a "diamond" character" available.
Can this be corrected.
pendean
Community Legend
Community Legend
You will need to create that shape: is there a challenge in doing that? Can you show us what you are looking for?
john.vellek
Hi Duncan,
Which font do you normally use to do this in other applications (outside of AutoCAD)?  I found that WINGDINGS and WINGDINGS2 had some shapes that might do this for you in AutoCAD.
Do you have an image of what you are looking for specifically? Perhaps I can help you find something that will work.
John Vellek
gotphish001
In a multi text window if you hit "alt 4" it puts in a solid diamond.  ♦
Nick DiPietro
Cad Manager/Monkey
@john.vellek the symbol on the right is the closest. However, "alt+4" might work.
john.vellek
Hi @Anonymous,
That's great that it could be so simple 🙂
If you use the Character Mapping Tool in Windows you can browse through any of your TTF fonts to find a variety of special characters.
John Vellek
abdaalahmed
Community Visitor
Community Visitor
You can copy past the diamond symbol from here (), and also you can read methods to insert the diameter sign. Click here to read all methods to make diamond icon.
