AutoCAD Forum
Folder Location issue with PDF Publishing
25 REPLIES 25
Message 1 of 26
designdistrict7
4921 Views, 25 Replies
I am having issue with PDf Publishing, everything was fine before few days, now even I am selecting a specific location for Output PDF, Cad is creating PDF in temp folder only. Please see below image for information. please help me how to fix this. I want to Publish my pdf in certain folder location not in temp. folder.  If possible tell me also how this error came, so I can be careful.
25 REPLIES 25
Message 2 of 26
would you please check from OPTIONS command >> Plot and Publish tab :
  • Plot to file location .
  • Auto Publish file location .
Imad Habash
Message 3 of 26
you might try to clean your %TEMP% folder, maybe you already have too many files or protected files in that folder(s).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 4 of 26
I checked , I don't see anything wrong, please see my setting in below image .img2.JPG
Message 5 of 26
same problem even after clearing temp. folder.
Regards
Message 6 of 26
HI, I found something on this link but I don't understand how to solve , can you explain me
https://forums.autodesk.com/t5/autocad-forum/publishing-temp-folder-in-path/td-p/5537864
Message 7 of 26
can you please start AutoCAD command _ABOUT and show us a screenshot from that dialog?
- alfred -
Alfred NESWADBA
Message 8 of 26
Message 9 of 26
thank you for the screenshot, it shows that your AutoCAD 2017 is not up-to-date, it should show 2017.1.2 as shown here:
Maybe installing this update already solves your question.
- alfred -
Alfred NESWADBA
Message 10 of 26
I don't know that will fix my problem, because up to May 28 everything was working good , and also I am having 2019 version but both suddenly get this problem after 28th , please take look on below image for version detail of 2019 , sorry for giving more trouble
Message 11 of 26
What changed on that day?
To verify if it's the installation or the AutoCAD user profile you might login as a different Windows user (create a new Windows user account on your system), then login with that account and
  • try to start AutoCAD and publish in normal way
  • turn off antivirus and test again
  • right-click the AutoCAD desktop icon and use option "start as administrator" and try the same again
...anything better here?
- alfred -
Alfred NESWADBA
Message 12 of 26
As you said i just logged in another user and published to a selected folder and its worked , so how can i solve problem for my user.
Regards
Message 13 of 26
either this other user has more permissions in the destination folder or the AutoCAD profile is clean and not modified.
You might try to use command _OPTIONS ==> Tab Profiles and export a profile to create an ARG-file (in the user account that works well), then login with the account that does not work and import the profile, make sure it's used as standard profile, restart AutoCAD and try publishing again.
A more direct method would be to export all settings (not just the profile) from the "good user account" and import the settings in the "other user account" 😉 as described >>>here<<<.
- alfred -
Alfred NESWADBA
Message 14 of 26
designdistrict7 -
By chance, do you have ProjectWise installed?
How about the computer you logged into and successfully published?
-Bruce
Message 15 of 26
Yes ProjectWise is nstalled on my PC. As Mr.Alfred said, Publishing to selected folder is working with other user. but my current user is publishing to tem folder only.
Message 16 of 26
The reason I ask is because we had the same issue and upgrading ProjectWise has resolved our issue.
In our case, we upgraded from .167 to .262
Maybe something to check on your end.
-Bruce
Message 17 of 26
When I use the PUBLISH command in AutoCAD, a dialog pops up first. On it, I have 'Publish to:' set to PDF, and Publish Options is available to use. clicking on that, I have 'Prompt for Name' checked, and I also have a Location set. If the location is not the same every time, at least the process stops to ask for a name, at which point I can choose the location.
You mentioned "my user", which leads me to think it's a new install or a new update for that user, and this is just one of the many things that needs to be set up for him/her to work the same way as your other users.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 18 of 26
Thanks for the information, Currently my PW version is .167 , i will try to update and come back to you with a result.
Regards
dD7
Message 19 of 26
I had users turn off "Background Publishing" as a workaround until their PW was upgraded.
-Bruce
Message 20 of 26
Thanks, not working for me , waiting for an  PW update from my IT team. any other option?
Regards
dD7
AutoCAD Inside the Factory
