AutoCAD Forum
Flattening a 3D DWG to 2D [SOLVED]
7 REPLIES 7
Message 1 of 8
31195 Views, 7 Replies
I have a 3D drawing and I want to flatten the whole thing to 2D isometric drawing(including objects and dimension labels). I have tried the flatshot command, but it just freezes AutoCAD and doesn't work. I have attached the 3D drawing I want to flatten and was wondering if anybody could be of any help or if perhaps has a computer that is strong enough to use flatshot.
Thanks in advance.
[The command Flatten ended up working - SOLVED]
7 REPLIES 7
Message 2 of 8
BAD SCREW THREADS
Message 3 of 8
john.vellek
Hi @Anonymous,
Perhaps your initial attempt to do this failed due to some drawing errors. I suggest that you run AUDIT to repair. I found 20 errors.  After they were corrected I was able to run Flatshot without any issues.
John Vellek
Message 4 of 8
Instead of breaking the 3D model;
In Paper space alter the viewpoint in a viewport to 1,-1,1, and you're looking at an iso of the 3D model.
Message 5 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 6 of 8
in reply to: john.vellek
I am encountering the same problem with flatshot command. I have reviewed again the structure in 3D to avoid having modelling errors that would cause this issue.
Kindly find attached the drawing if anyone might have a solution to it.
Thanks in advance,
R
Message 7 of 8
john.vellek
Hi @raissa92,
I think the issue you are seeing is because your geometry is made up of 3DFaces.  Flatshot is intended to work with solids and surfaces.  I changed some of your geometry so I could use a simple PRESSPULL to create walls that are 3D solids instead of faces. You will see in my video that once there are solids, FLATSHOT now works.
John Vellek
Message 8 of 8
Ok,
Here we go,
I am trying to take a manufactured supplied 3D drawing and make some isometric drawings out of it.  I have tried the suggestions that have been made here and it is not working for me.  Can someone please see if they can help with this?
Here is the drawing:
AutoCAD Inside the Factory
