AutoCAD Forum
flatshots in Autocad 2015
9 REPLIES 9
Message 1 of 10
468 Views, 9 Replies
I am having trouble doing flatshots in Autocad 2015.
Previously it was working fine.  Now on the same drawing, that has been working, it is giving message that there are no solid objects.
Also it has done flatshots previously, where it has left 'block' objects out of otherwise successful flatshot.
I am working in model space to do flatshots; all objects are x-ref'd in.  There are not any x-ref within x-refs.
I tried changing all x-refs from overlay to attach but it made no difference.
Stewart
9 REPLIES 9
Message 2 of 10
pendean
Can you post a DWG with the problem here for others to examine?
Message 3 of 10
I too have same problem in Autocad 2015.
It says something like "No geometry generated".
Message 4 of 10
JDMather
Message 5 of 10
in reply to: JDMather
Flatshot works in autocad 2014 but not in 2015. So, I don’t think the problem in the model of file. I think its version of autocad. Anyway, the file is attached herewith.
Sent from Mail for Windows 10
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Message 6 of 10
here is the file
Message 7 of 10
here is the file
Message 8 of 10
JDMather
Is there a logical reason you are trying to use flatshot rather than viewbase command?
Message 9 of 10
I have never used viewbase. It seems that it works only in the paperspace from what I read on the internet. I use flatshot to extract the front, back and side views and modify it to give it more details, and dimension it to produce working drawing in modelspace itself. Can I do these things using viewbase?
Message 10 of 10
JDMather
@Anonymous wrote:
....extract the front, back and side views and modify it to give it more details, .... Can I do these things using viewbase?
Modelspace is for 3D models.
Paperspace is for 2D views and detailing.
Exactly what viewbase is for.
AutoCAD Inside the Factory
