AutoCAD Forum
First click doesn't work for line, copy, move
22 REPLIES 22
Message 1 of 23
3016 Views, 22 Replies
First click doesn't work for line, copy, move..Pickfirst is set to 1. Can any of you suggest a solution please?
22 REPLIES 22
Message 2 of 23
ennujozlagam
PICKADD set to 1
Message 3 of 23
Vinayv4v
Is this behaviour same in all your drawings.
If PICK Variables doesn't help try resetting autocad to defaults.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Cheers,
Vinay Vijayakumaran
Message 4 of 23
imadHabash
>> First click doesn't work for line, copy, move <<
first click for a line command is completely different from copy and move commands ... would you please describe more your issue ?
Imad Habash
Message 5 of 23
in reply to: ennujozlagam
I think this was part of the issue... Where is the setting that controls the selection of objects? As of right now I have to select the object first then invoke a command. I want vice versa
Message 6 of 23
Message 7 of 23
Vinayv4v
The pickfirst Variable in Options (Op).
0 = Off. You can select objects only after you start a command
1 = On. You can also select objects before you start a command
Cheers,
Vinay Vijayakumaran
Message 8 of 23
in reply to: Vinayv4v
Thanks for this. This all was checked.
Message 9 of 23
All settings were reset to default
Message 10 of 23
Kent1Cooper
@Anonymous wrote:
.... Where is the setting that controls the selection of objects? As of right now I have to select the object first then invoke a command. I want vice versa
I can understand that in relation to Copy and Move [the PICKFIRST System Variable as others have already noted], but what does it have to do with the LINE command included in Post 1?
Kent Cooper, AIA
Message 11 of 23
pendean
This happens ALL the time, or only occasionally?
What is your AutoCAD version and variant?
What add-ons do you have running?
Windows OS is what?
Is this a sudden problem today, and it's everywhere?
Running in two monitors, and you launch commands from one monitor but draw on the second?
Get a new mouse or updated mouse driver recently?
You are describing a Loss-Of-Focus in regards to the program window, your mouse thinks some other program window is active, and why you have to click once to activate the window and once again to use a command.
Message 12 of 23
in reply to: pendean
It looks like hardware is causing this. I installed this on another machine and all seems fine. What specifically could be causing this?
Message 13 of 23
Vinayv4v
Are you using the move & copy commands from the ribbon tool bar?
Check your QAFLAGS variable. Is it 0 or 1. The default value is 0.
If it is 1 then make it 0 and check if the commands are working.
Cheers,
Vinay Vijayakumaran
Message 14 of 23
it's set to 0...I use both...this didn't help
Message 15 of 23
Basically, I need to press the mouse button at least three times to activate the command...extremely annoying.. any ideas gents?
Message 16 of 23
Kent1Cooper
Faulty mouse button?
Kent Cooper, AIA
Message 17 of 23
in reply to: Kent1Cooper
nope..I tried different mouse..but thank you for suggestion.
Message 18 of 23
All updates and service packs are up to date on both software's as well as Windows 7 Pro. Drivers are also up to date. I have no clue...Any help will be greatly appreciated.
Message 19 of 23
in reply to: imadHabash
Imadhabash,
I have to click multiple times to select the object..two times to start drawing the pline, two times to select the object..there is no pattern that I can observe...sometimes I can select the objects without any problems.. another time I need to click 2-3 times...
Message 20 of 23
I think I found the solution. Touchpad delay is causing all of these issues. I disabled it and removed software that was blocking the touchpad. Thanks for the help.
AutoCAD Inside the Factory
