@boicottms wrote:
When starting a new hatch often you can't immediatly get a correct scale....
If and when you are doing simple parallel-lines patterns such as ANSI31 [one direction] or ANSI37 [both directions, there's a very easy way to get exactly the scale you want, right off the bat. Just use the User-defined option. In the Hatch dialog box, pull down the Type: list and pick that:
Then you get to tell it directly the spacing [in drawing units] between the lines, rather than try to figure out what kind of multiple you need of whatever the spacing happens to be in a pattern's definition. And you get to tell it directly the direction the lines should run, so for vertical lines you just ask for 90 degrees, rather than having to know that you need to ask for a rotation of 45 degrees to get vertical lines from ANSI31. And you specify whether one direction only or also the perpendicular direction for cross-hatching.
Unfortunately, I don't have any better suggestions for other types of patterns, since they're so affected by how each pattern is defined and the scale you're working in. When I define a pattern, I always make some reasonable aspect of it one unit, so that I can get the size of the repeat of that aspect directly from the scale I apply, but sadly, many of AutoCAD's pattern definitions are not done that way [ANSI31 has lines 1/8 of a drawing unit apart when used at a scale factor of 1, for some reason].
Kent Cooper, AIA
