2017 object enabler software
I'm looking for where to download the 2017 object enabler software. I'm trying to edit my walls and was told I needed this to do so.
thank you!
RobDraw
Open the file and AutoCAD will tell you which one you need, most likely the one for AutoCAD architecture. You can then search for it.
Rob
Alfred.NESWADBA
Here you can find the object enablers from Autodesk for AutoCAD 2017 >>>click<<<
Sorry, not true.
Object enablers are used to view, delete, plot objects from verticals (or 3rd party applications).
But to edit such objects, you'll need the application itself.
As you wrote "walls" you might need AutoCAD Architecture, if you have a subscription for AutoCAD including toolsets then you can download and install and activate AutoCAD Architecture.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
you can see, move, copy and erase "walls" in plain 2017 with the object enablers installed, but you cannot edit them. You will need to upgrade to the same autocad variant that created those walls. Try it and see for yourself, Autodesk did not leave back doors in software open like that.
Available OEs for 2017 are here https://knowledge.autodesk.com/support/autocad/downloads?release=2017
how do I know which one I need?
cadffm
If you can see the walls correctly, you don't need an OE.
Your wrote about missing grips, so i guess if you select a wann, properties palette [CTRL]+[1] says "AEC WALL" or similar and NOT "PROXY Object", right?
( https://forums.autodesk.com/t5/autocad-architecture-forum/wall-grips-not-showing-up/m-p/9178717 )
If objects are PROXY objects: Set Proxynotice to 1 (on), open the DWG and take a look to  the dialog about proxy objects.
See the scrollbar.. Informations about companies and products will appears.
Upload your DWG and we all can help, but not if you try to edit autodesk architecture walls with plain AutoCAD.
Sebastian
