Find and replace different text in multiple AutoCAD files.
Message 1 of 16
I want replace different texts in multiple AutoCAD files. I have list of 'Original Text' and 'text to be replaced' in excel file. These text are more than 400-500 and these text may not be available in all files.
Refer attached sample excel file.
Please suggest solution for this query.
Pradeep
Replies (15)
Message 2 of 16
Alfred.NESWADBA
you might have luck with the tool shown in >>>that thread<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 16
TerryDotson
If you were to consider third party add-ons, DotSoft's ToolPac contains a Drawing Replace tool. Dialog example below showing one record from your list.
It processes multiple drawings quickly since they are treated as databases and not opened in the editor.  Script / Lisp combos tend to run slow and are subject to stopping before completion.  It's assignment specifications files are plain ascii, you could change your conversion table to one in about a minute in NotePad.
Message 4 of 16
rkmcswain
@Anonymous - see message #3
Message 5 of 16
Thanks for reply.
I am looking for free utility.
I don't want to type text for find and replace because I have huge number of text to tb replaced.
Hence input to be given in note pad file or excel file.
Pradeep
Message 6 of 16
vinodkl
Try out the lisp BFIND by Lee Mac. I have attached the same here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 7 of 16
Alfred.NESWADBA
Besides of it seems to be free ...
You are searching for a tool to make your job to be done with less effort/less time and so to save money. But you are not willing to donate the developer for his working time? That's a bit a one-sided earn situation, other's work is not seen as honorable ... that's why I stopped supplying free tools because the work and time of developers are seen that way (nothing worth they do).
- alfred -
Alfred NESWADBA
Message 8 of 16
I have tried this. But I have huge number (more than 300-400) of text to be replace.
I need to enter text  every time. I have list of these texts in note pad or excel. So that I can input this list for text replacement.
Message 9 of 16
maratovich
Is your text a text object or is it a multileader, attribute or other?
Attach an example of your dwg file
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 10 of 16
Hello Sir.
I respect you and other developers efforts as well.
I need this only for one time. All are asking queries. So I also asked.
Do not misunderstand me. I only asked for help. I am not making money by using your program's.
Thanks you.
Pradeep
Message 11 of 16
Please attached sample files of AutoCAD and PDF of same drawing.
Pradeep
Message 12 of 16
rkmcswain
How do you figure that? You are requesting a program to help you save time. Time is money, so yes, you are making more money by having this program to expedite the task.
Message 13 of 16
Dear Sir,
Okay.
Thanks for your valuable time.
I will do this manually.
Sorry for inconvenience caused to you due to my query.
Thanks.
Pradeep
Message 14 of 16
Alfred.NESWADBA
>> So I also asked.
No problem with that, it is very OK to ask, and a forum like that is the best place to do that.
My statement(s) about the developers efforts was simply because of "looking for a free utility". The statement "only for free" is something that hurts when you are developer spending efforts/time/... to create such tools.
But maybe there exists such a tool that is free, that does exactly what you want, then take it, and at least send a "thank you" to the developer.
- alfred -
Alfred NESWADBA
Message 15 of 16
maratovich
Here is the solution:
www.kdmsoft.net
Message 16 of 16
Solved.
