Filling (hatching) Objects
Message 1 of 10
I am trying to create two solid blocks. I started by drawing a rectangle. I then extruded them to the height that I wanted. I've tried using the hatch command to fill it. When I select hatch, it tells me to select an internal point. I then select any of the points since I want to fill the entire object by the time I'm through. I keep getting a message starting that "A closed boundary could not be determined. Any suggestions? I've been able to fill two sides total (1 from each block) but I'm not sure what exactly I did different than the other times.
Replies (9)
Message 2 of 10
Johanna_Esteban
Hello @Anonymous,
Your piece is already a solid, if what you want is to shade each of its faces, you must locate the UCS on the face you want to shade and then make it one at a time.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 3 of 10
I typed "UCS" then placed it at the corner so that it is perpendicular and
parallel to the different faces. I've then selected "gradient". I was not
able to apply a gradient to any of the faces other than the very bottom one
(which I was able to do even without setting the UCS.
Message 4 of 10
Here is my current file.  Thanks for the help.
Message 5 of 10
WarrenGeissler
Type UCS, then FACE to locate on a face you select, then the hatch will work.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 6 of 10
Kent1Cooper
On a 3D Solid, Hatching is probably not what you want.  Look into the MATERIALS command in Help, and related topics.
Kent Cooper, AIA
Message 7 of 10
WarrenGeissler
I second what @Kent1Cooper says!
Warren Geissler
Message 8 of 10
I'm having exactly the same issue with the same error, and would love a solution. In my case, I'm trying to make a 3D block look like glass, and after several hours I have gotten nowhere. To the original poster: If you solve your issue, could you post step-by-step instructions? I will probably be able to follow it more easily since we are both new.
Message 9 of 10
injineri
maybe from SOLIDEDIT>face>color do what you want
Message 10 of 10
Alfred.NESWADBA
Have you read through the whole thread? The suggestion to use materials instead of hatches is your solution.
Please follow these steps:
  • create a box
  • switch to visual style "X-Ray" or "Conceptual" or "Realistic"
  • start command _MATBROWSEROPEN
  • within the Autodesk library scroll down to / and select "Glass" on the left side
  • on the right side select the type of glass you prefer
  • drag & drop it onto your box in the graphic area
  • adjust view (camera) and lights if necessary
  • start command _RENDER
If that is not what you are looking for then please show us a sample of an image how you would like to have AutoCAD presenting a glass material/effect.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
