Message 1 of 10
Filling (hatching) Objects
06:30 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create two solid blocks. I started by drawing a rectangle. I then extruded them to the height that I wanted. I've tried using the hatch command to fill it. When I select hatch, it tells me to select an internal point. I then select any of the points since I want to fill the entire object by the time I'm through. I keep getting a message starting that "A closed boundary could not be determined. Any suggestions? I've been able to fill two sides total (1 from each block) but I'm not sure what exactly I did different than the other times.
