Filling boundary with hatch when the whole boundary doesnt fit display?
Had this problem for years, but never got around to ask. Lets say I have a very narrow and long boundary that I am trying to fill with hatch - if I zoom in enough where I can comfortably click inside the boundary, the whole thing doesn't fit on the screen and Autocad says boundary not found. If I zoom out where the whole thing fits, it becomes almost  impossible to click inside it because its so narrow.
Is there a way to override this behavior?
imadHabash
usually i took this area alone aside then make hatch . can you attache your narrow and long boundary for testing ?
Imad Habash
vinodkl
AutoCAD struggles when you using the "Pick" method to Hatch in such situations. So try selecting the boundary objects which you are trying to hatch or use the command "BOUNDARY" to create a new polyline boundary and then select that object to hatch boundary and then later on you can delete the polyline if you are trying to create a non-associative hatch.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
