Announcements
An Unclassified exception occured
while performing the STRETCH command on a combination call-out, autocad 2016 creates anotehr copy of the combination callout and ends up showing exception as "An Unclassified exception occured"
vinodkl
Check if your AutoCAD is updated to the latest version and also your OS is updated to the latest version.
Also check this article and see if it helps:https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unhand...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
