File Tabs missing after clean screen
Message 1 of 71
I have tried everything to get my open files tab back.  When I open  two or more files on my laptop (Autocad 2014) I have the multiple files open tab, and I can turn it off and on with either the ribbon button or the command line filetab/ filetabclose, but after using the clean screen option to better see a drawing then going back to normal viewing area the file tabs disappear, and neither ribbon or command line will bring it back. But after closing both drawings and reopenning them the file tabs are there until I use the clean screen command then click it again and file tabs are missing. I have tried multiple files so I know it is not a file issue. And now I have found that if I switch workspaces from one and back to mine they return, but after reopening drawings they are gone again. Is there a global system setting that needs to be changed?
Replies (70)
Message 61 of 71
Switch between different Profiles should help. I just accidentally pressed CTRL + 0 or some other key then My file tab was missing. Then I switch the Profiles to another one and then switch back to My set up profile. Everything is back.
Message 62 of 71
alexander.s.lizama
Community Visitor
Community Visitor
Worked for me, thanks!
Message 63 of 71
Honestly, I know that this will probably laughed at as a too simplistic of an answer but all I had to do to bring them back was to restart my computer and they are back.
Thanks to all the smart people that take time to post!!
Message 64 of 71
JamesMaeding
@Anonymous
Funny, the email i got on your reply says your account is archived.
Your idea is not an answer though, it is a known condition of this issue, and therefore cannot be concluded to be simplistic. I drew the venn diagram for this, and considered the conjunct of the bidirectional truth of the matter, and applied DeMorgan's law for qualifiers. The result was a new theorem: The account was archived for a reason.
Mine will probably be too after this 🙂
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 65 of 71
I faced The Same Problem, as I assume your issue- do the Below Changes------
Go to Option (Right Click from Mouse and last at the bottom)
And Do as showed in the Attached Picture---
SolvedSolved
Message 66 of 71
As a followup to the previous post, I found a more "user-friendly" workaround. Again, not a solution, but a better workaround than others suggested (if I may be so bold as to claim). I also attached three pictures to show anyone reading this what option/checkbox I am referring to in the "Options" dialog.
Perform the following steps:
1. Upon initially opening a drawing, make sure that in the "Options" dialog (type OPTIONS in the command line), you select the "Display" tab and have "Display File Tabs" checked. If it was on to begin with, you should have noticed a tab with your drawing's name up top somewhere (location is workspace dependent). If it is off to begin with, simply check it and press APPLY, then OK. Note: There is a chance that even checking this option and pressing APPLY then OK will not work, forcing you to close AutoCAD and restart it. However, upon restarting and reopening your drawing, it should remain checked ( I have yet to see it fail to display the tabs after this).
2. Do whatever you need to do, then activate "Clean Screen."
3. Notice that the file tab is missing (gasp!) and the "Options" dialog shows the "Display File Tabs" option as unchecked. By some "magic"/glitch/bug/whatever, it was forced off.
4. Close "Clean Screen."
5. Open the "Options" dialog again and notice that "Display File Tabs" option is unchecked. Check it and press APPLY and OK. No file tab will appear, but we have laid the foundation for the workaround. Note, if you were to close AutoCAD now and restart it, the file tab would reappear. Of course, that's not why I am writing this alternative procedure, as that has already been mentioned and if you have multiple drawings open, it quite frankly sucks to close them all and then reopen them. Instead, leave AutoCAD open and go to the next step.
6. The procedure at this step is entirely dependent on your workspace. If you utilize the "Ribbon" (the new style that utilizes panels of logical groupings of controls), then follow step 6A. If you are an fan of the "Classical" workspace, then follow step 6B. Since I recreated the "Classical" workspace from 2012 and imported it into the AutoCAD 2016 customization file, I do not use the ribbon, at all. Thus, I would follow step 6B.
6A. (Ribbon Users) Type RIBBONCLOSE in the command line. It will close your ribbon (resembling a "Clean Screen"). Then, type RIBBON in the command line and it will reopen your ribbon workspace. Notice that the file tab was restored! Strangely, now "Clean Screen" will also display the file tab and switching back and forth from "Clean Screen" will no longer hide the tabs nor force the option to be unchecked. If you were to close and restart AutoCAD, well, my friend, you are back at square 1.
6B. (Classical, Non-Ribbon Users) Type RIBBON in the command line. It will show the ribbon over your normal toolbars. Then, type RIBBONCLOSE in the command line and notice that the file tab was restored! Strangely, now "Clean Screen" will also display the file tab and switching back and forth from "Clean Screen" will no longer hide the tabs nor force the option to be unchecked. If you were to close and restart AutoCAD, well, my friend, you are back at square 1.
7. Enjoy the "workaround." I found that this persists so long as you keep AutoCAD open, so now subsequent evocations of "Clean Screen" won't screw up the file tabs until you close and restart AutoCAD (I am mentioning this again on purpose, as whatever bug is causing this has yet to be truly resolved).
Message 67 of 71
This works.  There are lots of little commands that can be activated unknowingly.  If your file tabs go away, use the line command FILETAB
Message 68 of 71
Doesnt work!!
Message 69 of 71
Type in "FILETAB" and they should come back on. At least that worked for me. Hope this helps.
Message 70 of 71
This actually worked for me. If i make sure the SDI is at 0 then put FILETAB I get nothing. But once I close and open again I get the drawing file tabs
Message 71 of 71
Marek.mikula
Community Visitor
Community Visitor
Success !
After trying about everything for last two weeks, finally turned of STARTMODE and filetabs just appeared !
Thank you for many suggestions !
