Field command using multiple? 2020
robert.danskin
robert.danskin
I have multiple rooms on multiple floors with a pline around each room.  I have discovered the field command, and love the way it works, however, it would take me forever to pick each room individually.  Is there a way to select multiple plines and have autocad 2020 place the sq footage in the middle of each pline?  eliminating the need to place the sq footage manually?
pendean
Community Legend
Community Legend
ВeekeeCZ
See THIS recent thread.
ВeekeeCZ
Use the one posted in msg #2. The rest was modified to work with HATCHes.
In case you haven't used a LISP routine yet, HERE is the a short tutorial of what to do with that.
robert.danskin
Thank you, by message 2, do you mean Areas to field and Area Label? If so, Areas to field is close to what I need, however, it appears I would still have to click on each field location to show the area of a pline. I have literally hundreds of rooms per floor, I am trying to avoid having to pick on each one individually. Are you aware of a routine that would allow me to pick multiple plines with a crossing or window and have the area field placed in the center of each pline?
Thank you
Bob Danskin
ВeekeeCZ
No, I meant in the thread I linked.
robert.danskin
Looks like you are directing me to PLArea? I am a newbie when it comes to lisp, do I simply copy the text for the routine and save it as a *.lsp, appload it and run it? Am I on the right track?
Thank you for your help
Bob Danskin
