FATAL ERROR
FATAL ERROR
qdst_nkgala
Message 1 of 9
FATAL ERROR
qdst_nkgala
 ASKING FOR HELP
Replies (8)
Message 2 of 9
gokcen.ezgi.sen
Hello @qdst_nkgala ,
I think the following article may be a solution to your problem;
"Fatal Error: AutoCAD Error Aborting" while working in AutoCAD Products
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Best regards,
Gokcen Ezgi Sen
MSc. Architect - BIM Consultant
LinkedIn
Message 3 of 9
qdst_nkgala
We're having some issue about cad/dwg file.
Some file doesn't open using higher version of AutoCAD like LT 2023 that we're using, but if we try to open that specific file in 2015 version of AutoCAD it can open and nothing issue
Message 4 of 9
qdst_nkgala
I thought its not hardware issue because were using Inter 11th and 12th Gen 16gb ram and windows 10/11 for the O.s
Message 5 of 9
gokcen.ezgi.sen
Hi @qdst_nkgala ,
There may be corruption in the old version AutoCAD file, old data or plugins causing conflicts in the new version.
I can suggest you to repair your file first and then try other steps with the methods mentioned in the link below;
Older drawing files freeze when opened in newer versions of AutoCAD
Best regards,
Gokcen Ezgi Sen
LinkedIn
Message 6 of 9
qdst_nkgala
still can't fixed the issue. Do you have another method? BTW thanks
Message 7 of 9
gokcen.ezgi.sen
Hi @qdst_nkgala ,
Is it possible for you to upload one of the files you're having trouble with so that I can examine what caused the error?
Best regards,
Gokcen Ezgi Sen
LinkedIn
Message 8 of 9
qdst_nkgala
See attached file
Message 9 of 9
gokcen.ezgi.sen
Hi @qdst_nkgala ,
I tried to examine the file, but I also encountered the same error and I did not have a chance to examine the project because I did not have the old version installed. I think the cause of the error is serious corruption in the file, or graphics card updates. As graphics card updates, such problems may be encountered in opening files that were working in the old version. You can even examine another discussion on this subject in the forums below;
fatal error unhandled access violation reading 0x0000 exception at
At this point, it was stated that replacing the graphics card updates with the old one would be the solution, unfortunately I have not experienced this, I am not sure it will work. But if you are sure that the file is intact and free of corruptions, you can try this method.
Best regards,
Gokcen Ezgi Sen
LinkedIn
