Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Fatal error: Unhandled exception in AutoCAD 2018
9 REPLIES 9
Message 1 of 10
2346 Views, 9 Replies
I'm using AutoCAD 2018. Since 2 days whenever I enter hatch command and select the pick point, a message pops up reading "FATAL ERROR: Unhandled Delayload "modlr22.dll" Module not found Exception at ccc03fb8h. Does anyone have a solution for this error?
9 REPLIES 9
Message 2 of 10
imadHabash
HI,
i suggest to install the latest service packs and updates from your AutoDesk desktop app . >> Click <<
Imad Habash
Message 3 of 10
in reply to: imadHabash
I have installed all the updates using the Autodesk Desktop App. No new update has come up yet.
Message 4 of 10
imadHabash
Ok.. does your problem issue happened in every dwg file or in a certain one ?
Imad Habash
Message 5 of 10
Every File. Even in a new file.
Message 6 of 10
imadHabash
would you try to reset autocad to default settings . >> Click <<
Imad Habash
Message 7 of 10
imadHabash
if resetting didn't help either. i suggest ( as a final step for me) to see if disabling or enabling hardware acceleration will help and solve your issue.type 3DCONFIG command.
Imad Habash
Message 8 of 10
Its solved. Thank you
Message 9 of 10
imadHabash
>> Its solved. Thank you <<
great to hear that.
all the best
Imad Habash
Message 10 of 10
where to write that commend ?
AutoCAD Inside the Factory
