Updating Excel file in autocad 2016
Message 1 of 10
I use Excel 2016 and AutoCAD 2016. When I bring in a table from Excel 2016 into AutoCAD 2016 (using copy from Excel 2016 then using paste special "paste link") to bring the table into AutoCAD everything seems to work perfectly but the shaded cells do not print with the shaded color. This works fine if I use Excel 2007 but we just upgraded to Office 2016 and I don't want to keep going back to the old 2007 version so I can bring in the tables. Any ideas why this doesn't print properly? It doesn't print when I print to PDF or directly to the printer. Everything shows up except for the shaded cell color.
Replies (9)
Message 2 of 10
WarrenGeissler
We'll need some samples from you. Attached is a PDF of an Excel 2016 Copy / Paste into Civil 3D 2016 (one as an OLE and one as AutoCAD entities) and the shaded cells work fine.
First - Which option in Paste Special are you using
Second - type ABOUT in AutoCAD and tell us which product version (and SP level) you are using.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 3 of 10
I am using AutoCAD Map 3D 2016: M020AP
built on: M. 49.0.0 AutoCAD 2016
The attached PDF file has 2 pages. The 1st page shows the Excel boxes as they print from AutoCAD and the 2nd page shows a screen capture of the same thing from AutoCAD. Notice that the yellow highlighted cells are in both versions on the screen but only print when the boxes are imported from Excel 2007.
I use "paste special" and the "paste link" "Microsoft Office Excel Worksheet" options to bring them into AutoCAD. This has worked for all my previous versions of AutoCAD and previous versions of Excel. This problem only started when we upgraded to Microsoft Office 2016.
Message 4 of 10
Another piece of information.
When I do a print preview, everything looks fine and the color shading in the cells show up fine then when I print the shaded cells do show up as shaded. I have tried printing to PDF, and 3 other printers directly and they all are the same.
Message 5 of 10
WarrenGeissler
Go into Excel - Click File - Click Account - Click the ABOUT EXCEL button. Are you using the 32-bit version or 64-bit version?
Along with that - I'm assuming you are on Windows 7 or 10 64-bit?
Warren Geissler
Message 6 of 10
I am using Windows 10  (64 Bit)
Excel shows as 32 bit.
So are I.T. guy installed the wrong version?  Can it be reinstalled as 64 bit?
Do you think that will fix the problem?
Message 7 of 10
WarrenGeissler
@Anonymous wrote:
 So our I.T. guy installed the wrong version?
Correct
Also correct
Unknown. However - that is the first thing I would look at. Most of the issues I've seen in Office products with AutoCAD belong to a mismatch of 32 vs. 64 bit loads.
Warren Geissler
Message 8 of 10
Thanks.  I will talk to my I.T. guy and see if that can be done easily. Where do I check my AutoCAD install to see if it is 32 bit or 64 bit?
Message 9 of 10
WarrenGeissler
If you are on a 64-bit OS, then you have a 64-bit AutoCAD. That's the only one that can install. Autodesk (unlike Microsoft) is nice that way.
Warren Geissler
Message 10 of 10
Thanks.  I will get my I.T. guy to reinstall Office as 64 bit and see what happens.
