exploding an xref
exploding an xref
Message 1 of 10
exploding an xref
how can an xref be exploded?
Replies (9)
Message 2 of 10
You cannot explode an xref, however, you can explode a block.  First convert the xref into a block by binding it to the drawing then explode it.
Message 3 of 10
Patchy
Want the whole xref drawing? use BIND
Want a part of xref? Xcopy
No way to explode xref.
Message 4 of 10
tommelberg
Observer
Observer
how do you bind an xref to a dwg?
Message 5 of 10
cadffm
Command XREF,
select your DWG XRef(only DWG!)
RightClick on this selected item..
Read about bind ootions in your help first.
Sebastian
Message 6 of 10
tommelberg
Observer
Observer
REFEDIT works as well
Message 7 of 10
cadffm
That must ve a hidden feature in Refedit 😄
Sebastian
Message 8 of 10
tommelberg
Observer
Observer
I'm finding alot of 'hidden features' in this 2022 version...as opposed to 2008.
Message 9 of 10
c_heintz
Observer
Observer
The issue is that I cannot bind it either as that option is greyed out. Can I please just be able to simply flatten the visible layers in a dwg in one simple file?
Message 10 of 10
pendean
Community Legend
Community Legend
@c_heintz wrote:
The issue is that I cannot bind it either as that option is greyed out. ...
that usually means the xref that is selected is a "child" xref, aka it resides in another XREF you have loaded.
@c_heintz wrote:
...Can I please just be able to simply flatten the visible layers in a dwg in one simple file?
May I ask if just opening that XREF (XOPEN or right-click in the XREF palette to select OPEN), doing what you need to do, QSAVE, close then reload it an option?
