Fatal Error (Unhandled Access Violation Reading 0x0048) Launch of AutoCAD 2018
Fatal Error: Unhandled Access Violation Reading 0x0048 Exception at 61122e2bh
@Anonymous,
john.vellek has edited your subject line for clarity: Fatal Error on Launch:
J.FOCHT
Hello @Anonymous,
I would suggest checking to see if your graphics card can handle what AutoCAD throws at it. You can go to autodesk certified equipment page and see if your graphics card shows up. It could also be an issue with the drivers for the graphics card. Make sure you are running the most current driver. One more suggestion would be to uninstall and then reinstall the .NET framework. Here is a nice article that highlights how this is done:\
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinstall-the-Microsoft-NET-Framework.html
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
john.vellek
Hi @Anonymous,
I am sorry that you are seeing this error on startup.  Please update your graphics driver to v. 390.65 from nVidia while I examine your CER report that you submitted. I am hoping it will give us an idea of what is going on with your system and AutoCAD.
[EDIT]  The CER did not contain too much.  If you have any 3rd party plug-ins could you remove those and try again? Lastly, please try a Reset Settings to Default to correct the error.
John Vellek
@john.vellek wrote:
Hi @Anonymous,
I updated my graphics drivers, now I am getting a new error after doing the same steps. I do not have any third party plug-ins.
FATAL ERROR: Unhandled Access Violation Reading 0x0048 Exception at 610f6cabh
[EDIT]: I reset my settings to default. Fixed this error! Thank you for the help.
JustOpie
Is this the actual solution? This did not resolve my problem.
I did a file copy of the folder for AutoCAD 2018 located in the Program Files folder from a known working PC to the crippled PC. This allowed the program to start on the crippled PC without the error.
john.vellek
Hi @JustOpie,
Yes, the solution above did correct the original poster's issue.
Your solution, is a bit unorthodox but I am glad it resolved the problem for you.  In the future, i would suggest a REPAIR and then possibly a Reset Settings to Default.
John Vellek
JustOpie
Well, after the Repair was performed, the error continued to occur. Therefore, I chose this option. It beat spending hours uninstalling and reinstalling the software. This took about 10 minutes to perform after all the other solutions I could find.
