Fatal Error: Unhandled Access Violation Reading 0x0008 Exeption AutoCAD 2017
Message 1 of 8
Newly Installed AutoCAD 2017. The program couldn't start perfectly and i lost about 7 days uninstalling, installing, finding solution from the internet. It Always shows a message all the time.
Fatal Error: Unhandled Access Violation Reading 0x0008 Exeption at d732065ah.
I have win10 Home Single Language 64-bit
NVIDIA Geforce GT 630
Please help me solve this i appreciate you a lot and you can save my life for another 7 days again.
I attached a photo for our reference.
Thanks to all!
Replies (7)
Message 2 of 8
dgladfelter
Errors like this can be difficult to track down. The first thing I would try is downloading the Autodesk-recommended graphics card drivers for your machine. You can do that at http://autodesk.com/graphics-hardware
In addition to the graphics drivers, I would also make sure to install AutoCAD 2017 SP 1 from the Autodesk Account site (http://accounts.autodesk.com), or Autodesk Desktop Application.
Beyond those troubleshooting steps, you may need to submit a ticket to Autodesk. Before doing that, I would recommend entering your email address into the CER report dialog that opens when AutoCAD crashes. Telling Autodesk that you submitted that report will let them better dig into what might be causing the crash.
Donnie Gladfelter
Virtual Design Manager, Dewberry
The CAD Geek Blog
Facebook |Twitter |YouTube |LinkedIn
Message 3 of 8
TheCADnoob
Might be graphics related, give this a shot and see if it helps
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Starti...
CADnoob
Message 4 of 8
john.vellek
Hi @Anonymous,
I agree with @TheCADnoob, that a startup with the /nohardware option will likely tell you if you have a graphics card issue.  Start there and post your results.
You might also compare this driver with the one you have installed to see which one performs better.
John Vellek
Message 5 of 8
john.vellek
Hi @Anonymous
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 6 of 8
Done this already that's why that error showed up. Thank you for the help. Smiley Happy
Message 7 of 8
Maybe it is my graphics card, I've tried  I just feel sad that Autocad Architecture 2016 works well on my PC but now when i tried 2017 it crashes all the time.
Thank you for the kind reply/help sir.
Message 8 of 8
john.vellek
Hi @Anonymous,
Did you try the newest driver that I suggested earlier?  If so, having a CER report as mentioned in a previous post as well as an NFO might help to determine what is causing the crashing.
Have you installed any add-ins? I would like to see if this performs properly in a new user account without and customizations.
You might also run a Diagnostic Startup to see if something else is contributing to the problem.
John Vellek
