Constraints command using (Autodesk Community Subscription Update)
Message 1 of 12
Dear Sir,
As Per your suggestion we upgraded OS to 64 bit.
Now we facing problem as, when we changes dimension for constraint drawing file angle dimension moving to random
position. If we manually select angle dimension and drag to its original place then drawing file get hanging.
Is any option or solution for angle dimension not change there position after any changes.
Regards
Ravi sagare
Replies (11)
Message 2 of 12
Alfred.NESWADBA
Which version of AutoCAD have you had before and which one do you have now?
Which service pack is installed?
Can you reproduce this in a new drawing? If you then please upload that drawing so we can look to the settings of your dimension-styles as well as to the dimension itself (I'm even surprised about a constraint dimension being red).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 12
Emmsleys
Does this issue happen on multiple files? Even a brand new drawing file?
Sarah Emmsley
Technical Support Specialist
Message 4 of 12
Dear Sir,
Yes this issue happening on both new and existing files.
And for below reply, dimension aren't displaying in red for your
information we made it red color.
after chaining constrained dimension other dimensions (like angle) are
moving, when we re positioning to its original position then drawing get
hanging.
please find attached drawing fine for your reference.
Regards
Ravi
being red).
Message 5 of 12
Alfred.NESWADBA
Sorry, nothing attached.
- alfred -
Alfred NESWADBA
Message 6 of 12
Dear Sir,
Please find out attached drawing.
Regards
Ravi
Message 7 of 12
Alfred.NESWADBA
please look to the forum >>>click<<<, there is no drawing attached.
If you are using a mail system to answer to the thread then attachments would not be sent, Please use the REPLY button in the forum and the ATTACHMENTS button to attach a drawing to a post here.
- alfred -
Alfred NESWADBA
Message 8 of 12
Dear Sir,
Regards
Ravi
Message 9 of 12
pendean
Community Legend
Community Legend
Come to the website to attach your file, do not send it by email.
Message 10 of 12
Dear Sir,
As you requested we attached file for your reference.
Ravi
Message 11 of 12
Alfred.NESWADBA
just a confirmation, I can reproduce the issue (angular dimension moves when the value of the angle changed) ... using AutoCAD 2017.1.1
Sorry that I don't have any (efficient) idea how to work around that.
- alfred -
Alfred NESWADBA
Message 12 of 12
dear Sir,
Kindly give any alternative solution for same.
Regards
Ravi
