fatal error: Unhandled Access Violation Reading 0x0000 Exception at 509fd089h
AutoCAD 2010 실행 후 특정한 도면 실행 시 오류발생합니다. 왜 이런 현상이 일어날까요?
TheCADnoob
john.vellek
Hi @Anonymous,
Is this  error showing up every time you open a drawing or when you save one? Is it always the same drawing(s) that cause this error or is it all of them?
If it is just one or two files then try running Audit and Purge on them.  If it is all files then I suggest you perform a Reset Settings to Default and verify also that you graphics card driver is up to date.
John Vellek
항상이 오류를 일으키는 동일한 도면입니다.
해봤지만 안됩니다
Our PCs used to fatal error repeatedly, turned out to be memory usage issue. Long and short was because we were running 32bit and maxing our page file and ram. Upgraded ram and changed to 64bit fixed it. However, this also meant we reinstalled the software.
john.vellek
Hi @Anonymous,
Can you attach the file to a post for me to look at? I hope that I can determine what is causing this error for you.
If you have already run Audit and Purge, can you also try -PURGE>Regapps?
Another method to cleaning the file would be to move via copy/paste or insert, the parts of the model into a new empty file. Then, use Design Center to import the layouts.
John Vellek
john.vellek
HI @Anonymous,
If you feel that this is unique to a file, can you please attach it to a post or email it to me if it is private? If you email, send to john.vellek@autodesk.com and include a link to this thread so I knw what it pertains to.
John Vellek
