How to create a tool palette network?
Hello Everyone,
I just started a  new job at a company to help them create AutoCad Standards. I am creating dynamic blocks and putting them into a tool palette. Is there a way to create a file location or something, where If I updated the tool palette, everyone elses tool palette is already updated. I'm just an engineer so this is a little beyond my level. I saw an article where I can export my tool palettes into a network location (as read only), then go to Options and add a tool palette location to this file, but that doesn't seem to do anything. Please help.
pendean
Community Legend
Community Legend
This guide should help you get started: http://www.neit.edu/blog/index.php/2015/08/autocad-share-your-tool-palettes/
There are even more resources on the web, and youtube videos too, try a search if you get stuck.
This article unfortunately just shows how to export a tool palette, I am trying to setup a network location that automatically update other users to have the tool palette.
kadmonkee
create the network location create a TOOL PALETTE folder and place all your containers and resources in this folder
create a container for each category
Electrical Group
POWER                Containers will host all Dynamic , Annotative blocks that relate to Power
LIGHTING
ONE LINE
FIRE ALARM
NURSE CALL
GENERAL ANNOTATIVE SYMBOLS
when you populate these containers on your network location you can use Design Center to create your Tool Palettes
when you browse to the location of your containers in Design center select the Blocks category in the left side, in the right side you want to select all the blocks to be included in your tool Palette- right click and select CREATE TOOL PALETTE
Once the Palette is created RENAME it (POWER) for this example.
to Rename it select the tool Palette tab , right click Rename
after you have completed creating your tool palettes you will then need to go into Options and provide the location under Files
select ADD browse to the designated location of all your containers then move that location up in the order.
this will prioritize what is seen first.
After you have created your Palettes you can now create a group to organize them for easy access.
right click on the tool palette side bar and select Customize Tool Palttes
in the right side close all other groups and select a blank space and right click select NEW GROUP Name IT ELEC CUSTOM all of my ELECTRICAL tool Palettes will become part of this group
then drag the tool Palette from the left side to the ELEC CUSTOM group on the right side.
after you have populated your group you should export that back to your Network TOOL PALETTE folder.
repeat steps  for each TOOL PALETTE AND GROUP
now you can isolate the tool Palettes by group right click on the sidebar and select the group you want to display
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
pendean
Community Legend
Community Legend
Yes, you EXPORT your TP to a central server location for others to share. Alternate steps if you have no TP content to start with is well addressed in the reply above.
Dive it, get started, post back if you get stuck. This is not going to be an easy task on your part to do.
once its setup on a network location a simple lisp function can be devised to call that tool palette or the OOTB or allow the user to define his own local palette alternating between the different palettes as desired.
(princ "\n                 ToolPalette Utilities...")
(defun c:tpcs () (command "*_toolpalettepath" "N:\\ACAD2015\\CS\\Palettes\\cs" "toolpalettes"))
(defun c:tpstd () (command "*_toolpalettepath" "C:\\Users\\%USERNAME%\\AppData\\Roaming\\Autodesk\\AutoCAD 2015\\R20.0\\enu\\Support\\ToolPalette"  "toolpalettes"))
(defun c:tpmy () (command "*_toolpalettepath" "C:\\Users\\%USERNAME%\\AppData\\Roaming\\Autodesk\\AutoCAD 2015\\R20.0\\enu\\Support\\ToolPalette_2"  "toolpalettes"))
(princ "   ... Loaded")
(princ "\n      Use TPSTD for Standard ACAD Palette")
(princ "\n      Use TPCS  for Civil-Structural Palette")
(princ "\n      Use TPMY  for Personal Palette")
(princ)
The "N:\\ACAD2015\\CS\\Palettes\\cs" in the code above is our dept. network customization location, edit that bit to match yours.
You can use the above to access numerous "standard" palettes for "families" of tools.
Check out Matt Murphy at AU2015
kadmonkee
thanks for that @Anonymous
I dont do well with programming lisps.
a huge help for consistent access.
thank you
