- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
My AutoCAD crashed when opening the drawing from my colleague. see error below:
I can open all my local drawings, and my colleague can also open the drawings that I sent. Only I can't open his drawing (we are all using AutoCAD 2016 and have all the latest service package and hotfixes installed). I looked for the solution from internet and got follow suggestions, and I did the modification according to the suggestion. After that, although I can open the drawing, but it became really slow.
In AutoCAD 2007-based products or later, the Performance Tuner is used to configure 3D, visualization, and hardware video acceleration settings to match the capabilities of your video card. Modifying these default settings could cause performance or stability issues in the application and may also prevent the program from launching successfully. To get AutoCAD to launch under this circumstance, run the program with basic software video acceleration. Follow these steps:
- Right-click the AutoCAD-based product icon on either the desktop or the Start menu and click Properties.
- In the Properties dialog box, click the Shortcut tab.
- In the Target field, edit the content to have the /nohardware switch at the end. For example:
"C:\Program Files\AutoCAD 2015\acad.exe" /nohardware - Click OK.
Double-click the modified icon to launch your AutoCAD-based product. Once the program has launched successfully, you can refer to the AutoCAD-based product Help file for information about configuring your system using the performance settings.
thanks for checking my question
regards
Hunter
