AutoCAD Forum
FATAL ERROR 71B1BEEh how do I fix it
1 REPLY 1
Darkforce_the_ilogic_guy
353 Views, 1 Reply
One I work with get this error all the time.
I have try updating he program to the neweste version (2020) both Autocad , Inventor , And Factory
It might be only be Autocad files that are Created by Factory  but I am not sure
He can open the Drawning but when he have added at one or just a few dimension it will get this Error and close the program
Labels (1)
1 REPLY 1
if you start a new CAD dwg and start working have you found same error or what ? if NO .. then try to clean your CAD dwg files by RECOVER , purge , Audit and _purge ( Regapps )  commands.
if you still found the same error then i suggest to check some solutions here that may help . >> Click << or >> Click1 <<
Imad Habash
Forma Design Contest
AutoCAD Beta
