AutoCAD Forum
Extruding a helix
3 REPLIES 3
rb26d3tt
360 Views, 3 Replies
Extruding a helix
Hello.
I need to extrude a solid object out of a 2D shape which is partly made with a helix, arc and lines.
I cannot make the outer part a region, which I need to do to extrude it properly.
The inner circle is mean to be subtracted from the outer shape to make the final model.
3 REPLIES 3
parkr4st
in reply to: rb26d3tt
fix the line work in the red circle.  it will extrude.
rb26d3tt
in reply to: parkr4st
Much appreciated. How did you manage to find it?
parkr4st
after fix
new layer
boundary, select region option if it pops up & redraw center circle
extrude to solids
subtract inner disc.
Technology Administrators
