Hello.
I need to extrude a solid object out of a 2D shape which is partly made with a helix, arc and lines.
I cannot make the outer part a region, which I need to do to extrude it properly.
The inner circle is mean to be subtracted from the outer shape to make the final model.
Hello.
fix the line work in the red circle. it will extrude.
Much appreciated. How did you manage to find it?
after fix
new layer
boundary, select region option if it pops up & redraw center circle
extrude to solids
subtract inner disc.
after fix
new layer
extrude to solids
