AutoCAD Forum
Extract Bill of Materials
5 REPLIES 5
850 Views, 5 Replies
how to extract and use Bill of Materials in autocad 2017?
5 REPLIES 5
Alfred.NESWADBA
the best command to get as close as possible to a BOM is to use command _DATAEXTRACTION (>>>details<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
A true BOM does not exist in core AutoCAD.  You can find this feature in AutoCAD Mechanical though.
What kind of project are you working in? Is DATAEXTRACTION as suggested by @Alfred.NESWADBA enough to do what you are trying to obtain?
John Vellek
beyoungjr
Be mindful that a data extraction will only work well if you are using Block objects and optimally if the blocks are using attributes.
The data extraction can serve as a BOM but it's in no way setup for that specific task alone.
Blaine
Blaine Young
Senior Engineering Technician, US Army
Alfred.NESWADBA
in reply to: beyoungjr
Just to add, you can also export polylines, lines, arcs, ... and export lengths and layer-names, which also might be part of BOM 😉
- alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Forma Design Contest
