Express tools menu not showing in the Ribbon !!
Message 1 of 12
Good afternoon.
I have an installation of Autocad 2020 where I cannot see the express tools menu in the ribbon. Express tools is installed and working: I tried different commands like tcount, attin and estratt , but even if I lauch the commands expresstools or expressmenu from command line the menu in the ribbon still does not show. The expressmenu and the expresstools commands seem to to nothing. What could I try to make the express tools menu appear in the ribbon? I tried to look up in the forum but I didn't find anything that solved that issue
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Its a tab, not a menu, unless you want to turn on MENUBAR command to get all menus to appear.
If I may ask, how many tabs do you have in the Ribbon? Post a screenshot.
Have you tried changing workspaces and see if that Ribbon Tab appears?
Message 3 of 12
imadHabash
right click on ribbon tab and select from show Tabs options.
Imad Habash
Message 4 of 12
I tried to change workspace, but nothing changes. Here is the screenshot
Message 5 of 12
pendean
Community Legend
Community Legend
Message 6 of 12
In my case there is no express tools tab to show. Please see the attached file
Message 7 of 12
imadHabash
if you type EXPRESSMENU in command line , any changes ?
Imad Habash
Message 8 of 12
No, nothing happens. I don't even get an error, it looks like the command is executed, but nothing happens
Message 9 of 12
pendean
Community Legend
Community Legend
Start CUI command and let us know if you see EXPRESS installed?
Message 10 of 12
No, EXPRESS looks absent
Message 11 of 12
I loaded the acetmain.cuix file in CUI and now the tab is showing. Thanks to all that contributed.
for the record, I followed the instructions here to load the file
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/screencast/Main/Details/61ccb9f9-7...
Message 12 of 12
thomas.kingQDNNE
Observer
Observer
Thank you! Many of the other solutions I tried did not work. The linked video was the way!
