- Mute
- Permalink
- Report
When there is an mtext in the file that is defined by a field such as the "Filename" field name, then if the command
-ExporttoAutoCAD is ran it produces the AutoCAD Error Aborting "Fatal ERROR: Unhandled Access Violation Reading 0x0020 Exception at 8955FB86h".
This is an issue as all of our output tabs have these mtexts and in order to clear corrupted files from proxy objects when someone accidently saves from C3D then we need to be able to run the -ExporttoAutoCAD command.
Has anyone had this issue in AutoCAD standalone? Because the one difference if nobody else is having this issue is we are working in Carlson which runs off of AutoCAD. So I am wondering if it is a Carlson issue.
Thank you
