- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day, if I use the Export Pdf function from the drop down menu (from the A icon, top left) I get a pdf output which is of lower quality and about double the file size than by plotting to pdf directly from the drawing itself. The reason why I am asking for help is that the driver and pc3 setup that I am using are exactly the same in the two modes, namely Autocad PDF (High Quality Print).pc3. All the settings I am using are exactly the same. The reason why I want to use Export PDF is that it automatically creates a file with the various layouts (pages), while if I plot directly from the layout I don't have an option to plot all layouts at once, which forces me to plot each and every layout separately and then merge them with a pdf editor.
PLease let me know if you know of a fix or alternatively if you know how to plot all layouts at once with the Plot command.
Much appreciated,
Marco
