AutoCAD Forum
Exporting Heightmap from AutoCAD
5 REPLIES 5
1283 Views, 5 Replies
I'm working a team member to try and figure how to export a heightmap file from AutoCAD.  We have a file that contains elevation data we just need to be able to export it properly.
We need the file to be the following:
  • 16-bit
  • Grayscale
  • PNG or RAW file
I'm hoping this is obvious and we are simply missing something.
Could someone help us out?
We are trying to get the data from AutoCAD to Unreal Engine.
If the file is only 8-bit you get the steps presented in the one attached file which we're trying to avoid.
Labels (3)
5 REPLIES 5
S.Faris
I would recommend you to post the same question on the Unreal Engine forum. There might be users who are well versed in these type of workflows.
SALMANUL FARIS
Valentin-WSP
Starting with AutoCAD 2019, support for the import and export of the FBX file format has been removed.
To convert a DWG file to FBX format, append the drawing in Navisworks and then export from Navisworks to FBX, or use AutoCAD 2018.  (Command:  FBXEXPORT)
Autodesk Maya can also export FBX files.
  1. Launch Maya.
  2. Select File > Export All, or File > Export Selection.
  3. Select FBX from File of Type menu.
  4. Enter a name for the FBX file you want to export.
  5. The FBX Export options appear at the right of the Maya Export dialog box.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
in reply to: S.Faris
I'm afraid I've already posted on two separate Unreal forums with little
response as they see it as an AutoCAD based question.
Tudor
pendean
>>>...they see it as an AutoCAD based question...<<<
AutoCAD is the wrong tool then for your needs: find another software option as discussed here https://forums.autodesk.com/t5/autocad-forum/exporting-heightmap-from-autocad/m-p/10435238#M1055929
Pointdump
Hi Tudor,
Welcome to the Autodesk Forums.
"...how to export a heightmap file from AutoCAD."
Your "043-ue4-heightmap-guide-02.jpg" shows a Digital Elevation Model, which can be a GeoTiff, USGS DEM, ASCII Grid, HGT, etc. It came from somewhere other than AutoCAD. Can't Unreal Engine directly import the DEM file? (I'd never even heard of Unreal Engine.)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
AutoCAD Inside the Factory
