Exporting CLEAN images from a DWG to a WORD document ?
Message 1 of 29
Hi !
My name is Greg, I teach metal working in Geneva, Switzerland.
As a teacher and I often need to export to Word documents and other formats some drawings I make on Autocad.
Usually some little drawings, no big things.
Stuff like that:
Is it possible to export them as clean as they are when printed and with the correct lines thicknesses ?
The best way I've used sionce now is to print them in PDF and make a capture of the PFD then paste it in the Word document but the quality is not 100%...
Please heeeeeelp !!!
Thank you !
GR
EG
Replies (28)
Message 21 of 29
EPS prtinter method is not a solution for now since Microsoft doesn't support EPS images anymore.
https://support.office.com/en-us/article/support-for-eps-images-has-been-turned-off-in-office-a069d6...
Message 22 of 29
mrsanjeevyadav
Community Visitor
Community Visitor
I paste screenshot in MS Paint than crop it and save as jpeg or other format but quality is poor in word.
Message 23 of 29
Yes, I for now I sadly still haven't found a practical way to have clean
results...
Message 24 of 29
Alfred.NESWADBA
Have you seen the other suggestions like using PDF, this helps to get a better quality.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 25 of 29
Yes, that's what I use but it's not 100% satisfying! : )
Message 27 of 29
tboehler
The Printing from CAD to PDF and then saving to jpg (600 dpi) works great.  I get very clean and crips linework.
or
Doing a copy link from CAD then paste special into Word as "Picture (windows Metafile)" also works very well.  FYI - you can modify your layout tab in CAD to Display Plot Styles - this will make your copylink look just like the intended plot.
Attached is an example word doc.  Page 1 is the PDF route, page 2 is the copy link route.
*Screen captures are not used.
Message 28 of 29
Thank you very much, I'll try it!!!
Message 29 of 29
See the material in the link below works
Inserting DWG's into MS Word or PowerPoint - The CAD Geek
The "Cad Geek" seems to have a good handle on this
