When i enter line as a command, and then try to enter a certain length, it gives me this long number instead of my length.
Solved by Alfred.NESWADBA. Go to Solution.
Sorry, not clear what you mean by "this long number".
In most cases when an input to a command line does not work as expected it's worth to play with the dynamic input setting (icon in status bar or <F12>).
- alfred -
Hi and Welcome to AutoCAD Forum,
>> When i enter line as a command, and then try to enter a certain length, it gives me this long number instead of my length. <<
i just want to remind that you have first to specify start point with mouse then when asked for next point enter your needed distance. if not that your issue please try to describe it more .
Imad Habash
Found this looking via google, had the same problem now it's fixed, thanks to the forum.
